sorry about the question i have to use the school computar feels weird comen back after you finish last year
HID
HID
i got a new car a couple of weeks ago and well i hate the lights i drive in the country a lot, I live in a small town outside of calgary... i only cleared my head lights last time but it was sanded a reclearcoated looks like new had one new light from the last owner and couldnt tell them apart after so im getten that done and HID i wont the ones that sill have the hi beam the h4 i beilve how hard is it looks easy form what read and whats a good brand seems xeon is popular? and its HID low beam and holagen hi beam? correct?
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
- JWMX3
Re: HID
if you want high and low beam HIDs, you need to buy the Bi-xenon kit, like this http://cgi.ebay.com/ebaymotors/HID-Xeno ... ccessories
- mitmaks
Re: HID
I'm looking at this kit. http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT" onclick="window.open(this.href);return false;
Is it any good or should I get something else. Driving at night especially after it rains sucks really bad. I might as well hold a candle, this is as much as my stock headlights work. I can't see nothing.
- mitmaks
Re: HID
I want to use my stock light housings.
Re: HID
As long as proper projectors are retrofitted into the housing and there is no glare going into the eyes of oncoming drivers, then I shall not claim your second-born child...third-born if the second-born is ugly...mitmaks wrote:I want to use my stock light housings.
- mitmaks
Re: HID
so I can't use HID kit with stock headlight housings?
- _-Night-Shade-_
Re: HID
You can do whatever you want, lots of people do HIDs with stock housings, it's fine. The little details don't matter, stock headlights suck.mitmaks wrote:so I can't use HID kit with stock headlight housings?
- mitmaks
Re: HID
Another member on here recommended this seller/kit. I don't see difference except price
http://cgi.ebay.com/ebaymotors/Canada-S ... ccessories" onclick="window.open(this.href);return false;
- _-Night-Shade-_
Re: HID
Yeah HIDs must be a popular selling item in eBay, there's literally thousands to choose from as a result. The only things you really need to keep in mind is that it's 9004, that you're getting the whole kit and not just the bulbs, the regular/slim ballasts is just that - the size of the ballasts and won't make any difference other than take up less space, and regular kits will have halogen hi-beams so if you want HID hi-beams you need to get that bi-xenon kit.
Re: HID
Stock headlights suck, but they are still designed for halogen bulbs. Halogen reflectors cause glare. Period. Ever had the pleasure of driving by someone with their high beams on?_-Night-Shade-_ wrote:You can do whatever you want, lots of people do HIDs with stock housings, it's fine. The little details don't matter, stock headlights suck.mitmaks wrote:so I can't use HID kit with stock headlight housings?
For example, see the three hotspots above the cutoff? That's what blinds other people on the road. Even if you aim the lights retardedly low, the hotspots will still be there.
This is an example of a horrible HID hackjob. Notice the light output all over the place. When you install crap like this, you are actually downgrading the performance of your lights.
Even with the Spyder projectors (look for the topic with 8364589324645742 pages, only one on MX-3.com), there looks like there is going to be a horrible hotspot right smack in the middle. I will be cracking mine apart to see if there is anything I can do to eliminate the hotspot completely before the HIDs go into it.
Now this is an example of OEM HID installed in a proper housing. Notice the sharp cutoff and no hotspotting.
tl;dr version: installing HID bulbs in halogen housing = rice and stupid
- mitmaks
Re: HID
the last picture looks like someone partially shut garage door and it looks like "sharp cutoff". Can you post a picture of HID's w/projectors shining on the garage door?
Re: HID
More examples of proper OEM HIDs
Up-close of the "step up" in the lighting
This one looks like an European-spec projector. Notice how it slants up as opposed to "stepping up" like you see in the ones above.
Basically, proper HID lighting would have a wide spread of light, razor sharp cutoff with a step or slant up on the right side for lighting up signs. This is of course assuming you drive on the right side of the road and not the left.
- mitmaks
Re: HID
So I can achieve same quality of light with ebay projectors?
s1zzl3
Re: HID
the third pic down that flyer posted is what they will look like when the spyder projectors are installedmitmaks wrote:So I can achieve same quality of light with ebay projectors?
i thought it was said that the "hotspot" above the spyder projectors was due to glare from the water in that pic...?
either way thats the best your gonna do for the mx3
unless you retrofit.
