megasquirt
Posted: December 20th, 2009, 6:22 pm
by blackknight
I'm trying to turbo my 93 gs se with a klze and i was wondering if you anyone can help me with a wiring diagram for straight into the harness not tap into the ecu???
Re: megasquirt
Posted: December 20th, 2009, 6:41 pm
by JWMX3
have you tried here
http://www.MSefi.com
Re: megasquirt
Posted: December 21st, 2009, 3:10 am
by fowljesse
I tapped the ECU, and may bypass it.
Re: megasquirt
Posted: December 21st, 2009, 9:11 pm
by mx3autozam
This is how mine is setup, thanks to Nd4spdse who did it originally. It is running as full standalone and connectoed to the pins on the back of the yellow connector for the ecu. the ecu pins have all been cut and don't power the ecu at all. Its pretty much the ecu case so its sorta like a plug and play setup.
![Image](http://i97.photobucket.com/albums/l227/mx3autozam/turbo/DSCF0280.jpg)
Re: megasquirt
Posted: December 21st, 2009, 11:16 pm
by blackknight
have you tried to install it????
Re: megasquirt
Posted: December 22nd, 2009, 12:19 am
by Ryan
Why not just take the yellow female plugs out entirely, and scrap the case?
Re: megasquirt
Posted: January 8th, 2010, 4:22 pm
by mx3stylez
wow!!! that is really nice. i just finished most of my wiring, but i think i may do it over to mimic this setup. very clean!!! i have a 96 but when i started wiring, i found that the 4th plug in my ecu can be totally eliminated if you have a wideband. the 4th plug is only for o2s and egr
