KLZE gasket
KLZE gasket
So im freshening up my KLZE with new parts. water pump, time belt kit. oil pan n sealant. valve cover gaskets. but what should i do about the intake gasket. intake to cylinder head??? arnt the ports shaped different??
Re: KLZE gasket
ZE gasket has square port openings, so everything matches. You can get a Millenia gasket, should be the same. But actually, the gasket is metal and is usually in good shape, so you can reuse it.
Re: KLZE gasket
sweet thats what i thot just wanted to make sure. the gaskets only $6 thru my buddys acct at worldpac. ill just order a new set. thanx again
- JM1EC-V6
Re: KLZE gasket
KL-ZE IM gasket P/N: KL31-13-111A
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
Re: KLZE gasket
For your intake use these thermal spacers. Check out this site. http://www.outlawengineering.com/MazdaK ... Frame.html" onclick="window.open(this.href);return false;
