MX3ZE - T
Posted: November 30th, 2009, 12:08 am
K801 V6 1.8 Stock engine
KL-ZE engine
KLZE heads
New clutch
KL-ZE and MX6 Tranny
Engine bay
Millenia IM
Compression test
210 205 210
205 210 210
Running KL-ZE
KL31 ECU
Paint job
CAI
New stainless steel brake lines
Interior
Tokico shocks + Eibach springs
Turbo
Turbo markup
As you will see, number of clearance issues will have to be addressed
Now to address clearance; in most cases heat and bang-in and/or trim/cut.
Install
Hot pipes
Oil sensors/return
Turbo
Intercooler
Intercooler and cold pipes ground clearance
Millenia S injectors
Coolant hose
WG and rad fan
Blow off and AIT
Almost finished
MS Install
KL-ZE engine
KLZE heads
New clutch
Engine bay
Millenia IM
Compression test
210 205 210
205 210 210
Running KL-ZE
KL31 ECU
Paint job
CAI
Interior
Turbo
Turbo markup
Install
Hot pipes
Oil sensors/return
Turbo
Intercooler
Coolant hose
WG and rad fan
Blow off and AIT
Almost finished
MS Install
