spec stage II+
mccabe
spec stage II+
Post by mccabe »
ok so my gs just got wrote of by the insurance copmany so i have already started to take my kl out but my friend has a bpt with a g series tranny will my clutch work on his car??? the pressure plates look the same... :shrug: thought i would ask the clutch has only 8 thou ont so i would like to sell if if i could..
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Ryan
Re: spec stage II+
Post by Ryan »
V6 and I4 flywheels are very different.
mccabe
Re: spec stage II+
Post by mccabe »
i know thw i4 sohc ones a alot different but the actual bp flywheel looks quite a bit the same?
JWMX3
Re: spec stage II+
Post by JWMX3 »
why not go on the spec site and compare part numbers
but i guarantee they are different
Return to “Transmissions”
