check engine light/bad mafs.....noob
Posted: November 6th, 2009, 9:33 pm
by kurt5153
hey guys i just got a 92 mx3 with the 1.8 v6. well the check engine light came on. so i checked the mafs n its making a ticking noise, so is it bad or is there something els i can check? also is there a way to remove the weird a-- cone?lol
Re: check engine light/bad mafs.....noob
Posted: November 6th, 2009, 9:35 pm
by Ryan
Huh?
Put your intake back together and check the FAQ's for pulling engine codes.
If you take that cone out of the MAF, you no longer have a MAF. You're clearly not understanding the purpose of the unit.
Posted: November 6th, 2009, 9:37 pm
by kurt5153
i understand the purpose of the mafs i just never seen one like this b4 just thoucht you can remove it like removing the screens off them.
Posted: November 15th, 2009, 12:49 am
by Slammed6
Thats because we don't have a MAF we have VAF (Volume Air Flow Sensor)
Posted: November 15th, 2009, 12:54 am
by Ryan
We have both.... he does have a MAF.
Whats so weird about it? Its some sort of barrier on a spring. Aren't they all like that? I guess, except hotwire ones.
Posted: November 15th, 2009, 1:22 am
by Slammed6
Ryan wrote:We have both.... he does have a MAF.
The K8 and the KL do not use a MAF
Posted: November 15th, 2009, 2:40 am
by Ryan
Technically, you're right, but its how we(MX3.com) distinguish between the cylinder cone style and the trapdoor type.
Posted: November 15th, 2009, 2:49 am
by Slammed6
Ryan wrote:Technically, you're right, but its how we(MX3.com) distinguish between the cylinder cone style and the trapdoor type.
Just getting the clarification out there.... "cone style" is a VAF, and the "trap door style" is a MAF. This is for the man asking about why this "MAF" does not look like all other MAFs he's seen. Cause its not a MAF, its a VAF.
Posted: November 15th, 2009, 11:22 am
by Ryan
You're hurting my head
If you want to get techincal neither MAFs or VAFs are exactly what their name implies, as only hotwire MAFS actually measure the density of the air. The rest just measure the volume, and rely on the 02 sensor to fine tune to fuel ratio.
I had always been calling the cone style a MAF and the trapdoor a VAF. They are really the same design though, measuring volume and not mass or density.
Posted: November 16th, 2009, 5:01 am
by Slammed6
Well I will always call it a V-A-F, as that is its name and It is what Mazda calls it. So feel free to call it anything you want.
Posted: November 16th, 2009, 7:37 pm
by kurt5153
Thxs guys for ur help n all lol, so I got a vaf off a mx6 for 10 bucks, well I put it on n my starts then dies, so I put the old vaf on it n it started fine then idled high but no check engine light. Then it came back on n started to idle weird it now bounces form 1000-1500 rpms, so I changed that vaccume sensor n the light went out, only 2 are pluged in n if I plug the 3 one in the light comes on but still bounces from 1000-1500rpms? HELP
Posted: November 18th, 2009, 8:45 am
by Slammed6
You can't use a VAF off an MX-6 if your using a K8 ECU. It is not calibrated the same. You have to stick with a MX-3 or a 929. The VAF must say JE-50 on it, not a Probe or MX-6 which says KL-01/02.
Pull the Check Engine light and see what code comes up...start there
