Rear Tie Bar Instalation
need some help installing my rear tie bar.. anyone?? i know where it mounts on and all that, but im just not to confident and would like the help of someone who has done it before.
----"A Real Car has 3 Pedals"----
2007 Satin White Pearl Subaru Wrx 2.5L
2007 Blue Subaru Impreza Sedan 2.5I Special Edition - Sold
1996 Black Mazda MX-3 RS - Sold for Part
- umcamara
Re: Rear Tie Bar Instalation
Are you talking about a strut bar, or the performance rod that bolts to the rear-end under the car?
If it's the performance rod, the installation specs are in the online manual under the suspension heading. If it's the strut bar...it's pretty straight-forward... remove the nuts from the strut mounts, put the strut bar on, and put the nuts back on...
its the one underneith the car... ill check out the tech forum... thanks alot!
- mitmaks
it's not hard at all. I did mine in like 45 mins or so. Just two long bolts that come out and you carefully put it on and put bolts back on.
mitmaks wrote:it's not hard at all. I did mine in like 45 mins or so. Just two long bolts that come out and you carefully put it on and put bolts back on.
lol wow 45 minutes is a lonngg time to do that, you probably did it in way less time then that . but your right its literally 2 bolts and then putting them back on,
NEED PARTS INSTALLED? PM ME!
![Image](http://i453.photobucket.com/albums/qq253/projectzemx3/avator2.jpg)
see i started using the impact gun to take em out, but it looks like the is a nut on the end of the bolt, and i wanted to pull the nut off, but it seemed like the entire bolt was comming out... maybe ill spray some pen oil on it than try it out
- mitmaks
You have to hold nut with a wrench while unscrewing bolt with a socket from other end.
Where can I find them I have looked all over eBay where can I get some
- RS_OBD'oh_2
no longer made. Try a junk yard if you don't have a GS.
try http://www.corksport.com" onclick="window.open(this.href);return false;
they have several performance parts for the mx3
![Image](http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/394120_373075049372748_100000107693468_1607713_658344921_n.jpg)
JDM MX-3 KLZE 2.5 W/ HEADERS, SHORT RAM INTAKE, FIDANZA FLYWHEEL, STAGE 3 CLUTCH, SHORT THROW SHIFTER, NOLOGY HOT WIRES, PAINTED AND POLISHED ENGINE, WHITE W/BLUE PEARL PAINT, ENKEI RPF1s 9.5lbs, COILOVERS, B-PILLAR BAR, 6K HID HEADLIGHTS, 12K HID PINK FOGS, PROSPORT GAUGES.
- RS_OBD'oh_2
puromx3 wrote:try http://www.corksport.com" onclick="window.open(this.href);return false;
Or you can save your time and not look for them there. They were an SRD product. They have not been made for several years.
Or you mean the ones I got reproduced and that my buddy can make for you...
yea i bought a replica from jimmie pearson... he was selling battery straps and tie bars, not too sure if he still has any to sell or not. look him up in the facebook group, you should be able to find him!
Ya, I believe he does. He asks me once in a while if anyone needs any.
