Adjusting valve clearance
onebrickshy
How hard is it to adjust the valve clearance on a stock V6 '92 or '94 GS? It looks to me like you have to take off all of the intake manifold and everything. Is this the case?
- Inodoro Pereyra
Re: Adjusting valve clearance
Do you mean valve lash?
If that's the case, it's impossible. The K8 engine has HLAs, so the lash is hydraulically adjusted.
Diogenes of Sinope.
Diogenes of Sinope.
hgallegos915
where did you get the idea to adjust the valves?
-hec
- mitmaks
probably used to older cars where you had to manually adjust valves. Not on these cars lol. Im sure if you were to take it to mechanic, depending on mechanic they would tell you that 'you need to adjust your valves".hgallegos915 wrote:where did you get the idea to adjust the valves?
As already stated the MX3 valve clearance is not adjustable. Many cars of similar vintage need valve adjustment as part of regular maintenence including most Toyotas and Hondas.
