EGR question
lost4good2009
EGR question
Post by lost4good2009 »
ok i have the vaccuum diagram for the klze, and i was wanting to get rid of my egr all together. I have acurved neck im so ill need one for the im and the block right? After that i can just use vaccuum caps for the egr solenoid right? and i never knew coolant lines ran through egr so what can i do about the coolant lines? block them off, or run them to something else?
lost4good2009
Re: EGR question
ha, nevermind wasnt as complicated as i thought, lol just ran the coolant line straight from the neck to the throttle body, so the coolant part of the egr is bypassed, and i made a block off plate for the egr, and i cut off the part where the egr tube bolts into the header and welded a patch over it, and put i 2 or 3 vavcuum caps over the open spots. :D
