Engine Upgrade...suggestions
swman01
Post by swman01 »
Which of these selections ( http://www.jdmenginezone.com/engines/jdm-mazda/" onclick="window.open(this.href);return false; ) or, other engines suggested by you all would be best to upgrade to and which ones could i put in my 93' ?.... i would like 1.8L but not sure what would work.
and thanks for all the help that i receive from everyone, this is by far one of the best sites that i found.
swman01
93' mazda mx-3
93vtecklr
Re: Engine Upgrade...suggestions
Post by 93vtecklr »
Hmmm, theres the b6t, bp from an escort/tracer, bp-t from the 323 familia? Would you prefer to stay naturally aspirated? Or plan on boosting?
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Ryan
Post by Ryan »
Start with a 1.8L BP. Then, if you're power hungry, boost that badboy. Takes 12 PSI on a good tune on stock internals. (almost stock STI boost)
Also, boost parts are readily available (manifolds, and such) because it IS a boosted motor in other cars.
Don't buy it from an importer, just get a junker motor, and if you'd like, rebuild it. Would still be cheaper and you'd have a reliable motor.
Dark_Rider2k3
Post by Dark_Rider2k3 »
^ What Ryan said :mrgreen:
I'm doing the BP swap and Manual swap currently. So far I've paid:
$650- Engine (roughy. It was 500 and I had it shipped via. my dads business)
$300- Clutch/Flywheel
$120- Short Shifter/Linkage/BP Seals off an MX'er (Trevo)
$40 (I think)- BP ECU
I am waiting on:
MTX Pedal Assembly, lines, center console piece from Ryan (but will be paying around.. $50 + ship)
Corksport Stainless Clutch Line
And I am in the process of getting, or will be getting in the future:
Manual tranny (have to call junkyards)
Port/Polish
BP Wiring harness (to get rid of my auto harness.. don't want the plugs dangling, and don't want to cut them off).
Axle Shaft/Hubs
Gasket set
Possibly buying a set of rims and Shifter boot off Nd4
Walbro Fuel pump
New Timing Belt and serpentine belts
Water Pump
Oil Pump
New hoses (maybe... I will make judgement when I see how my hoses are when they are off)
Stainless brake lines
Turbo manifold, and all turbo parts (need to research info on boosting before I do this so I know what to get)
Better exhaust then what i have. (I need a resonator badly).
There is lots more that I am going to do, but in terms of the engine itself, I am most likely going to leave it stock internals. From what I've read (and as Ryan said) it can take 12 PSI with stock internals. So considering I only wanted to do around 8-12 PSI, that will be fine with me.
swman01
Post by swman01 »
Oh yes i plan on boosting down the road, so that all helps out very much. i Noticed that you are doing a Manual swap aswell(dark_rider2k3). Would i have to get a newer tranny for mine, too? Im runnin with a Manual already, pretty sure i wouldnt need to get a newer one, but just to be on the safe side is that a good idea? tho i found no problems with the one i have now.
swman01
93' MX-3 1.6L 5Spd Manual
Redline322
Post by Redline322 »
You could keep your stock trans for now if you just get a regular BP, but to boost it, you'll need to look for a g-series trans out of an escort gt to handle the extra power. Most transmissions for the b series mazda motors are interchangeable, just use the flywheel that matches that transmission and it will bolt up perfect. Since your car is a 93, it more than likely is a sohc, which is almost exactly the same as a BP harness, you'd just need to add 3 wires, or just get a bp harness and it will be plug and play. A BPT is good if you wanted to turn up the boost and get some more power without having to source all the parts you want, but if you just want a stock tune, you'd be better off buying a junk escort gt with a good 1.8 motor and trans, swap all the goodies in and save some money.
I paid $300 for my BP
$200 for the trans and axles
$50 for harness, ecu and vaf
$150 for my turbo manifold
$75 for my turbo and lines
$50 for rx7 injectors
$100 for intercooler and couplers
$75 for intercooler piping
$225 for megasquirt
So, $1225 for a full turbo BP vs. the $1900 BPT and you'll need to get the intercooler parts with a BPT too, so add about $200 to your budget for that.
swman01
Post by swman01 »
Would the year of the Escort have to be 93'? or could a different year work?
Yet another opinion on note worthy engines. http://en.wikipedia.org/wiki/Ward%27s_1 ... th_Century" onclick="window.open(this.href);return false;
Redline322
91-96 escort gt, ideally not 91 since they had the small nose crank. Some protege lx's in the U.S. and protege gt's in Canada from 91-98 came with them too but you'd be better off going for an escort gt and finding a mazda valve cover because you are guaranteed to be getting a fwd g-series trans instead of awd.
swman01
Post by swman01 »
sounds good, i was ebay, and some other auto locator type sites searching around last night for an escort gt, but there were a couple of years i wasnt sure about. now that i know what i should shoot for, this gives me plenty of time to research and what not. Im not planning on the swap till early next year, so ill probably ask a few more questions till then but the help is greatly appreciated. Thanks
swman01
93' MX-3 1.6L 5spd
