Diagnostic Box
Posted: July 30th, 2009, 1:24 pm
by PTCS
I jumped the ten and the GND.. with a paper clip.. I also noticed that there are two plug ins for the GND. Hopefully, the proper GND is the one that is on the ten plug. After jumping the two I turned the ignition on. I heard a long click and a short click. which I believe to be number 11 code... Intake Ground Thermosensor... however, there was no long flashes and short flashes.. 1) did I put the paper clip in the right GND and 2) if it is an 11 code what does the Intake ground thermosensor do and what does it look like...
ptcs
Re: Diagnostic Box
Posted: July 30th, 2009, 3:23 pm
by Custommx3
Wrong section.. moved to engine electrical/lighting.
Re: Diagnostic Box
Posted: July 30th, 2009, 5:39 pm
by Mad Cow
Clicks have nothing to do with the codes, that's just some relay that clicks when you turn the key in diagnostic mode. Do you even have a CEL? And it doesn't matter what GND you use, a ground is a ground.
Re: Diagnostic Box
Posted: July 30th, 2009, 7:21 pm
by Ryan
Does the bulb come on at all? when the key is in the ON position before you start? If not, the bulb is burnt, or pulled out by previous owner.
Re: Diagnostic Box
Posted: July 30th, 2009, 9:40 pm
by Daninski
Umm, what year is your car?
Re: Diagnostic Box Help
Posted: August 1st, 2009, 12:26 am
by PTCS
Just put the engine in ... the mazda mx3 v6 1.8... have jumped the diagnostic box. Initially there was one code on the box code 12. .. throttle position sensor... I tried centreing the sensor... still coding... now there is a bigger problem.. everytime i put the car into gear.. the engine rpm revs up from 650.. to 1300 rpm... does anybody know what would be causing this... as well now instead of one code... 12.. I have a number of different codes as follows: 16, EGR Position Sensor, 17 Feedback system or closed loop system right syde.. 11.. Intake air Thermo Sensor Dynamic Chamber and 4 Distributor... The only real noticeale problem is, again, when the car is put into gear the idel moves up from 650 rpm to 13-1500 rpm.. take it out of gear (5 speed manual) and the rpm returns to normal.. does any body have any ideas re: all the codes and also whats causing the increase in rpms when put into gear..
thanx
ptcs
Posted: August 1st, 2009, 2:13 pm
by umcamara
PTCS wrote:Just put the engine in ... the mazda mx3 v6 1.8... have jumped the diagnostic box. Initially there was one code on the box code 12. .. throttle position sensor... I tried centreing the sensor... still coding... now there is a bigger problem.. everytime i put the car into gear.. the engine rpm revs up from 650.. to 1300 rpm... does anybody know what would be causing this... as well now instead of one code... 12.. I have a number of different codes as follows: 16, EGR Position Sensor, 17 Feedback system or closed loop system right syde.. 11.. Intake air Thermo Sensor Dynamic Chamber and 4 Distributor... The only real noticeale problem is, again, when the car is put into gear the idel moves up from 650 rpm to 13-1500 rpm.. take it out of gear (5 speed manual) and the rpm returns to normal.. does any body have any ideas re: all the codes and also whats causing the increase in rpms when put into gear..
thanx
ptcs
I don't think that was a model year...
Re: Diagnostic Box
Posted: August 15th, 2009, 12:47 am
by Newfie_dan
where are you located? I live in saskatoon and if your in the area I will be happy to look at it for you free of charge, I am a journeyman heavy equipment mechanic with about 13 years of automotive experience, so I know what I am doing no BS.
Re: Diagnostic Box
Posted: March 16th, 2010, 12:51 am
by shrooms258
lol perhaps you can look at my car?
Re: Diagnostic Box
Posted: March 16th, 2010, 1:02 am
by Newfie_dan
Again I would need to know whereabouts you live to help you out. If you can get the car to me I can take a look at it this weekend for you.
Re: Diagnostic Box
Posted: March 16th, 2010, 5:23 am
by SpatialTerror
wait a sec.
its throwing all those codes.
and it still starts?
hmmm.
like the last guy said.
what year is your car.
if its 1996 or newer
go get a obdII code reader.
saves alot of time and effort.
hope ur car is alright.
you know what this sounds like is ur ecu is freakin out.
because of somthing like a domino effect.
