klde
mccabe
klde
Post by mccabe »
ok so i found out that i gotta klde not klze so i have been readen the fourms about my ecu options so i hear i can use a mx6 ecu but my fans will stay on all the time. but if i chip my k8 ecu for a de will i have that problem
cts my gs ha two green and balck but the de dosnt have one how do i fix that?
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: klde
You'll have to drill and tap the DE. Just use a vaccum while your drilling to ensure no metal is left in the coolant line.
mccabe
Re: klde
Post by mccabe »
i my have to take my IM off could i swap the neccks????
Mad Cow
Re: klde
Post by Mad Cow »
You have a '92 so the coolant sensor thing isn't an issue, just use a '93 probe/mx6/626 ECU aand VAF and you'll be perfect.
EDIT: Whoops didn't read that your motor only has one coolant sensor. In that case pick up a '94 KLDE ECU and find which plug is connected to the ECU (most likely the green one). The problems people have are when their harness only has 1 plug and they have to use an ECU that needs both sensors.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
mccabe
Re: klde
Post by mccabe »
thank you mad cow thats what i wonted to hear
