Curved neck manifold, I need help with hooking up the EGR
Posted: July 15th, 2009, 1:19 pm
The EGR on the curved neck ZE manifold is quite different than our MX3/Probe EGRs.
The connector that connects to it, wont fit on it.
The curved neck EGR has 3 connectors in it just like our MX3/Probe connectors.
I am thinking of braking off the plastic thing on the Curved neck EGR and just soldering in the wires.
Im just wondering, are the connectors the same as the Probe/MX3 EGR?
Do the same 3 connectors that connect to the Probe EGR, work in the same order on the curved neck egr?
Like, for instance, if the left connector is the color green, middle is black and the one in the right is white, on the Probe EGR, will it be in the same order on the curved neck EGR?
thanx
btw, I want the EGR working
thanx
