Page 1 of 2
awr mounts confused
Posted: July 2nd, 2009, 3:56 pm
by mccabe
ok so i have a 92 gs so when i do my swap i wnt to order awr moutns but if i use the k8 tranny do i still order the probe front mount or is it only woith the mx6 626 tranny
Re: awr mounts confused
Posted: July 2nd, 2009, 4:07 pm
by wytbishop
It's the crossmember that causes the trouble, not the tranny. Just buy the ones everyone told you to and you'll be fine.
Posted: July 2nd, 2009, 4:31 pm
by solo_ryder
Probe front, mx3 rear no matter what tranny you use as you are gonna be using the k8 brackets on the tranny either way
Posted: July 2nd, 2009, 4:32 pm
by fieromx3
yes buy probe front and mx3 rear... ull have no issues
by fieromx3
solo_ryder wrote:Probe front, mx3 rear no matter what tranny you use as you are gonna be using the k8 brackets on the tranny either way
bah 1 minute to late LOL
Posted: July 2nd, 2009, 5:04 pm
by mccabe
ha ha wow fast responces ha ha just a little fieromx3 thanks guys
Posted: July 8th, 2009, 4:59 am
by RX8SE3P
Yeah he has to drill out the cross member holes a little to fit the mounts but that is not hard.
I got probe front and MX-3 rear also. Have not fitted them yet.
Posted: July 8th, 2009, 9:34 am
by hppwdn
The probe and MX3 front mount are identical except for the studs that go into the crossmember (17mm on the probe, 14mm on the mx3). I don't see why you have to order a probe one and drill out your crossmember when an mx3 one will pop right in. The larger stud isn't going to give any real gains, the tensile strength of the 14mm is fine.
Is there another reason people are ordering probe front mounts that I just haven't heard yet?
Posted: July 8th, 2009, 9:44 am
by solo_ryder
You are correct.
The reason why I and others say use the probe front is because awr obtained a front mount from mazda to make their mount for the mx3. For some reason they received and replicated a mount that is too skinny. My buddy has a mx3 mount and he has to run about 6 washers on each sidev of the mount to make it fit snug. Not a big deal, but the probe one does fit better.
Posted: July 8th, 2009, 9:59 am
by hppwdn
OK, good to know.
I've been working with mbolin on probetalk to make a full set of all four motor mounts for the MX3 V6. I sent him a spare set I pulled off a GS in the junkyard to use as templates. He makes the same style as AWR, but for a lot cheaper. It'll be quite awhile before the project gets anywhere, he said he might have some news by the fall.
Posted: July 8th, 2009, 11:29 am
by Mooneggs
hppwdn wrote:OK, good to know.
Sweet - I would definately be in to buy 2 sets of the 2 side mounts!
Posted: February 18th, 2010, 9:29 pm
by johnmx3ze
so did you get any news from mbolin?
im looking for awr mounts right now but if mbolin is doing the same style of mounts i will buy from him?
cause on awr its gonna come up to like 275$ for 2 mounts...
Posted: February 18th, 2010, 9:32 pm
by Mooneggs
good bump - I forgot about this but I'm definately interested in 2 sets of side mounts
Posted: February 18th, 2010, 11:41 pm
by hppwdn
mbolin packed up shop and stopped making parts so that project died on the table. I at least got him to send back my spare mounts and I went ahead and filled them with 94A urethane. Came out really well for a total cost of $33.
Posted: February 19th, 2010, 5:18 am
by turpro1993
If you guys are looking for those other 2 mounts let me know and I'll contact him
http://www.mx-3.com/phpBB3/viewtopic.php?f=39&t=72488" onclick="window.open(this.href);return false;
