Somple clutch question
Does the slave clutch cylinder have a bleeding screw?
Re: Somple clutch question
It does, it looks just like a brake caliper bleeding screw.
It's right there on the cylinder itself... unless yours was sheared off or something.
Looks like this... the knob thing on the bottom right... although when it is actually mounted it's the other way around
![Image](http://i10.ebayimg.com/05/i/08/5c/a9/52_1.JPG)
