Help diagnosing
- mitmaks
Help diagnosing
I got CEL, I've jumped TEN and GND and it flashes 2 short flashes (maybe long flashes??) not sure if they're long as I don't get any other flashes. What does it mean?
Re: Help diagnosing
search cel codes theres a whole tutorial on it as well as a list
It only takes a single voice to start a revolution
- mitmaks
Re: Help diagnosing
I did do a lot of searching, just not familiar with OBD1 system. Ive repaired a few OBD2 cars for friends/family as it's pretty easy.
If it's two short flashes then it's my Crank angle sensor...not sure how do I fix that. Is there anything for 2 long flashes, as I did not find it?
Re: Help diagnosing
viewtopic.php?f=3&t=69010&hilit=diagnos ... s&start=60" onclick="window.open(this.href);return false; cut and paste this and see if it helps as far as the crank angle sensor im not sure about that
- mitmaks
Re: Help diagnosing
Another question...where is crankshaft position sensor is at on K8?
Re: Help diagnosing
hmmm u have the same engine as me. im not sure where its at ask se7en hes got a boosted k8 and he knows the engines more than i do
Re: Help diagnosing
go to the main mx-3 page and in the side page on the left it says online manuals they have a engine manual for the k8
- mitmaks
Re: Help diagnosing
I know where online manual is, Ive read like 30% of it already lol. I just thought I'd ask to save me all that trouble searching. Good thing Ive been checking thing around, found out my rad cap gasket is bad and leaking a bit...not a good thing.chrome730 wrote:go to the main mx-3 page and in the side page on the left it says online manuals they have a engine manual for the k8
Re: Help diagnosing
see mit things work out now i have to work on my problems which is i have to read the whole brake section seeing as my brakes are trashed
- _-Night-Shade-_
Re: Help diagnosing
It's wayyy down there if you follow the oil dipstick till it ends beside the idler pulley. I got to mine from the side by removing the wheel and plastic cover.mitmaks wrote:Another question...where is crankshaft position sensor is at on K8?
- Ryan
Re: Help diagnosing
Wow, you guys all suck at this
The two flashes are dummy proof. Codes are made so you can't mix up 20 and 2 because there will only be one of those options.
Code tables are always in the emissions/control section. Thats F2 for the K8.
This is the table w/ code 2:
http://www.mx-3.com/manuals/showimg.php ... F2-077.gif" onclick="window.open(this.href);return false;
Here's the troubleshooting for it:
http://www.mx-3.com/manuals/showimg.php ... F2-079.gif" onclick="window.open(this.href);return false;
This is how to remove it/them:
http://www.mx-3.com/manuals/showimg.php ... F2-154.gif" onclick="window.open(this.href);return false;
It seems you have two "Crank angle Sensors" although the one in the disty seems more like a cam angle sensor to me... whatever. Although Code 2 is for CAS#2, the one in the crank pully area, not the disty one.
- mitmaks
Re: Help diagnosing
Thank you, I'll check that out.Ryan wrote:Wow, you guys all suck at this
- mitmaks
Re: Help diagnosing
Checked sensor today (meter set at 2000) and it says 561. So that means sensor is fine, why would it give me code 02 then?
- _-Night-Shade-_
Re: Help diagnosing
Did you check it when temp was around 20C? It reads lower when cold and higher when hot.mitmaks wrote:Checked sensor today (meter set at 2000) and it says 561. So that means sensor is fine, why would it give me code 02 then?
- mitmaks
Re: UPDATE
Well I went and bought new one from Napa $64. Old one I noticed if I put metal object to it (sensor has small magnet inside) it will fluctuate readings. Then it wouldn't read at all at times, then it would read over specifications. So I've installed new sensor and belts...runs pretty good right now.
