![Werd :werd:](./images/smilies/werd.gif)
I UPDATED MY SHIPPING PRICES, I MADE A MISTAKE ON WHAT CAN ACTUALLY FIT IN WHICH USPS FLATE RATE BOXES.:slap:
SHIPPING IS IN THE CONTINENTAL US ONLY! (CANADA +$7-$20..PLEASE ASK)
1)Autometer Universal 2 Gauge Pod With Autometer Vacuum & Volt Gauges- These are working, and in good cosmetic condition, but they are missing the light bulb socket in the back. But it in no way affects the function of the gauges.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0328091851-00.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0328091852-00.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0328091852-01.jpg)
ASKING $40 SHIPPED
2)1993 Ford Probe KL-01 Heads/Cams/Valve Covers Complete- These are in good working condition and they were pulled from a motor with lower end problems. Upon inspection everything looks top be in excellent condition, Great for getting head work done and a Camshaft regrind.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091151-00.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091151-01.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091151-02.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091151-03.jpg)
ASKING $ 200 SHIPPED
3)OEM Manifolds….1 KLZE EGR-less Rear Manifold, 3 OEM EGR Rear Manifolds, 2 Front Maniofld- I have these OEM manifolds great for projects, or replacement of your manifolds with broken studs/bolts.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091154-00.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091154-01.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091154-02.jpg)
ASKING $17/each SHIPPED
4)OEM Front & Rear Heat Shields- Need replacements, or use to cover your aftermarket headers.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091155-00.jpg)
ASKING $15/set SHIPPED
5)OEM Exhaust Manifold Gaskets- These are in good condition and are used but can be used more than once. I have more than 3 in the pic, I have approx. 6-8 gaskets.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091155-01.jpg)
6)OEM UNBROKEN Oil DipStick- They are rare, but here is one.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091155-02.jpg)
ASKING $15 SHIPPED
7)Slightly Damaged Timing Cover- It a complete timing cover set, just has some small damages, look at pics.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091156-00.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091156-01.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091157-00.jpg)
ASKING $20 SHIPPED
8)Rear Metal Timing Cover- No explanation needed
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091157-01.jpg)
ASKING $20 SHIPPED
9)Slightly Used Water Pump- This is in immaculate condition, gasket is still very rubbery and soft, I will include the pulley as well (not pictured)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091157-02.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091158-00.jpg)
ASKING $30 SHIPPED
10)OEM Alternator Bracket- Not broken and in good condition.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091158-01.jpg)
ASKING $15 SHIPPED
11)OEM Hydraulic Timing Belt Tensioner- Excellent condition, replace your old worn out Tensioner.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091158-02.jpg)
ASKING $30 SHIPPED
12)OEM KL-01 Crank Sensor- Pulled from a working Probe, In good condition.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091159-00.jpg)
ASKING $15 SHIPPED
13)OEM Alternator/A/C Tensioner- Good condition, pulley spins smooth and freely.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091159-01.jpg)
ASKING $20 SHIPPED
14)3-Sensor KL Water neck- These are a must for the KL motors that only come with 2-sensors and your harness has clips for 3. This will solve your problem of your fans continuously running.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091159-02.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091159-03.jpg)
ASKING $20 SHIPPED
15)OEM Mechanical Timing Belt Tensioner- Spins freely, and in good condition
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091200-03.jpg)
ASKING $25 SHIPPED
16)OEM Timing Belt Idler Pulley- Both spin freely, and in good condition.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/0607091201-00.jpg)
ASKING $15/each SHIPPED
17)SS Autochrome Turbo Pipes- These are in great condition, and there are no cracks or dents visible. THESE DO NOT INCLUDE THE DOWNPIPE!
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/DSC01165.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/DSC01167.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/DSC01168.jpg)
ASKING $150 SHIPPED
18)KL-01 Throttle Body W/IAC & TPS- This throttle body was pulled from a running Probe, Great for a core for a bored out throttle body.
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/DSC01085.jpg)
![Image](http://i90.photobucket.com/albums/k262/SlammedSix/For%20Sale%20Item/DSC01084.jpg)
ASKING $30 SHIPPED
