I basically want the biggest tire I can get for a 17 inch tire and that wont rub om the struts.
Anyone?
why would I want this? Im boosted, and want longer wheel ratio as ive seen it do wonders on my friends turbo mx3.
I havent talked to him in a while and i forgot what size he is running.
biggest tire for a 17 inch rim?
hgallegos915
-hec
- Bigpun4fubu
Re: biggest tire for a 17 inch rim?
well i am running 215/45/17's i bet you could go up to a max of 235/45/17's but that could get really close to the strut
1994 Mazda Mx-3 RS 1.6L DOHC Spectre High Flow Air Filter Bosch Platinum +2 Plugs, NGK R Wires, 17" ICW Racing Wheels with 215/45/17 Yokohama Tires Teardrop Exhaust
stereoking15 had a set of 235/45/17 and they DID NOT fit... he swapped them out for some 225/45/17 and they DID fit but that was after alot of grinding on the front strut perches + 5mm spacers. I believe the rears went on fine (no grinding) with just 5mm spacers.Bigpun4fubu wrote:well i am running 215/45/17's i bet you could go up to a max of 235/45/17's but that could get really close to the strut
- nsklzemx3
lol...im running 205/35/17 on stock suspension
'93 MX3
A work in Progress
CURENT UPGRADES: Curved Neck KLZE/Option Import Headers/2.5" Exhaust/Valeo OEM Clutch/Yonaka Motorsports Gaskets & Silicone Tubing/Option Racing CAI/MBX Probe Addiction Wires/Fidanza Flywheel
My Aloha 8.2: http://s162.photobucket.com/albums/t258/1981aloha27/Aloha 8.2
Matilta 20
Cygnus 20
Code 40
A work in Progress
Matilta 20
Cygnus 20
Code 40
