klze with kl31 ecu
klze with kl31 ecu
Hey I just bought a 95 mx-3 gs with a klze and the k8 intake manifold. It worked alright with the k8 ecu so then I tryed the kl31. It will start, rev up then die. I can keep it going with the throttle. I would appriciate any help.
Re: klze with kl31 ecu
It has whatever the last owner had in it. I tryed adjusting the idle and that didn't work.
so thats the only problem?
How do you mean the idle-set-up does not work?
http://www.mx-3-tom.de" onclick="window.open(this.href);return false;
http://www.mx-3-community.de" onclick="window.open(this.href);return false;
SWAP COMPLETE: B6 DOHC (16V) --> KL-ZE (24V)
![Image](http://home.arcor.de/tg_daten/mx3sig4_75px.jpg)
It wasn't idling so I tryed increasing the idle, and it still stalled.
Okay I just tryed the kl31 ecu again, and slowly increased the idle screw until it would idle by itself. It was idling at 4-5k and the intake sounded like it was backfiring. I set the idle down slightly and it wouln't stay running. Balls!
but it ran an idled fine with the k8 ecu? something is wrong with the ecu then.
NEED PARTS INSTALLED? PM ME!
![Image](http://i453.photobucket.com/albums/qq253/projectzemx3/avator2.jpg)
Ya, the different should be that drastic between ECU's for idle...I agree, gotta be the ECUprojectzemx3 wrote:but it ran an idled fine with the k8 ecu? something is wrong with the ecu then.
Well the idle was a bit lumpy with the stock ecu
I got a new ecu kl36 and put it in. I got it to idle, but during normal driving it surges a little. Full throttle is great. Sometimes it stumbbles when taking off.
If your k8 ecu is compatible, get it probinator chipped.
![Image](http://i659.photobucket.com/albums/uu316/93vtecklr/ClintsSig2.jpg)
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
