HELP!!!
Posted: June 1st, 2009, 11:50 pm
by Mx-3 Beginer
So here is my problem. My car was running fine(92 mx3/klze) and then the other day it wouldnt start it would turn over but not start. So i tryed bumping it and it didnt satrt but then i tryed turning it over after bumping it and it started. It has done this thre times already only when its cold. When its hot it starts fine???????? I dont know where to satrt any advice will help please.
Re: HELP!!!
Posted: June 2nd, 2009, 1:53 am
by jon_young
sounds like a buggered starter motor,
but pull ur ecu codes as well might be a couple of things that together stop it from working
Re: HELP!!!
Posted: June 2nd, 2009, 6:14 pm
by Mx-3 Beginer
Thats the thing the starter is fine it cranks and everything it just wont run
Re: HELP!!!
Posted: June 2nd, 2009, 6:53 pm
by Ryan
It could be 1000 things.
Did you pull codes?
The disty, and crank/cam/knock/airflow sensors could do this, the ECM, anything fuel related... its a massive list.
Re: HELP!!!
Posted: June 2nd, 2009, 10:46 pm
by Mx-3 Beginer
The guy i bought it off of took out the check engine light so tomorrow at work ill try to pull the codes and see.
