205/40/R17 on 17's?
- adamowich2613
205/40/R17 on 17's?
I have a 1993 mazda mx3 4cly, and i am looking at some 205/40/R17's i don't have the rims yet but the tires are new and a really good deal. If i get some 17" rims with these tires, will they mount up without rubbing or will i need spacers? Thanks.
>current wheels are stock 14" alloys with a 185/65/R14 tire if that helps
>car isn't lowered!
I need a response soon please.
>car isn't lowered!
Re: 205/40/R17 on 17's?
I'm running 215/40/17's, not an issue, therefore you will absolutely be able to turn lock to lock and never rub with 205's.
![Image](http://i659.photobucket.com/albums/uu316/93vtecklr/ClintsSig2.jpg)
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- adamowich2613
Hey thanks alot93vtecklr wrote:I'm running 215/40/17's, not an issue, therefore you will absolutely be able to turn lock to lock and never rub with 205's.
you are very welcome!
- johnmx3ze
thats what im running 205 40 17
![Image](http://i470.photobucket.com/albums/rr69/johnmx3ze/JonNEWsignatureVredSMALL.jpg)
I've got 205/40/17 as well.
I too have a 205/40/17 on a 17x7 rim... offset comes into play somewhere right? (i'm a n00b when it comes to tires and rims...)
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
- _-Night-Shade-_
I think 205/40/17 is the best combo! I'm running that as well ![Very Happy :D](./images/smilies/icon_biggrin.gif)
It does, but it would have to be some unusually high offset to rub those.Mooneggs wrote:offset comes into play somewhere right? (i'm a n00b when it comes to tires and rims...)
Why not run more rubber your going to realy feel the road and pot holes. I've got 215 50 17 they fit and have enough rubber they will ride like stock but change my gear ratio, I should rev a little lower on the highway now.
i used to run 205 40 17 as well. but if i were to keep my 17's i would go 205 45 17.
NEED PARTS INSTALLED? PM ME!
![Image](http://i453.photobucket.com/albums/qq253/projectzemx3/avator2.jpg)
- _-Night-Shade-_
Your tire size isn't going to alter your transmissiontrick69 wrote:Why not run more rubber your going to realy feel the road and pot holes. I've got 215 50 17 they fit and have enough rubber they will ride like stock but change my gear ratio, I should rev a little lower on the highway now.
![Confused2 :confused2:](./images/smilies/confused2.gif)
whats the tallest 17inch combo that we can run? Im looking to alter my 5th gear, and well more grip(turbo)
-hec
- onlytrueromeo
Well it won't alter your tranny but it will alter you effective gear ratio because you're increasing the size of the wheel, so you get lower revs/mph at the same actual speed. Just have to remember you're going faster than your speedo says you are!_-Night-Shade-_ wrote:Your tire size isn't going to alter your transmissiontrick69 wrote:Why not run more rubber your going to realy feel the road and pot holes. I've got 215 50 17 they fit and have enough rubber they will ride like stock but change my gear ratio, I should rev a little lower on the highway now.I hope you meant to say the speedo
- _-Night-Shade-_
Does it even make such a dramatic difference?
