Which coolant temperature sensor?
mok86
Post by mok86 »
I have a 94 RS DOHC, i want to replace this coolant temperature sensor: http://mx-3.com/manuals/showimg.php?fil ... F1-162.gif" onclick="window.open(this.href);return false;
as my idle drops very low when the car gets hot
What is the part # that i should get off rockauto? i know it's a 2 wire type but are TX40T, TX40 , 5S1517, TS10051 , D583 the same?
Or can it be this:
http://www.autopartsway.ca/autoparts2/i ... ~keysensor" onclick="window.open(this.href);return false;
( based in canada)
thanks.
Ryan
Re: Which coolant temperature sensor?
Post by Ryan »
Thats the green one, right?
I doubt its gone bad, but they are fairly universal. I'd try an autoparts store, only like $20. Should be easier, about same price, and you can compare it 1st hand to the one you have and return it if it's not the right one.
Internet shopping has some downfalls.
I'd try adjusting your idle otherwise before buying a new sensor.
This isn't the right way to do it, but let the car get to operating temp and slowly turn the screw found in that hole on the throttle body until it sits where you want. CCW I think for idle-up
mok86
Post by mok86 »
yea i bought the one from autopartsway.... i'll install this weekend and keep you updated
as for adjusting idle...the idle has been adjusted a billion times hahaha even my mechanic thinks its a devil car... haha like the idle sits at 1k but when it heats up it drops to 500... but this only happens if i'm paused for long enough as in 5 seconds or longer....otherwise it idles at 1k....if i adjust the dropped idle higher... it'll idle reallly high for stops shorter than 5 seconds def waste of gas lol...
heres hoping this will fix it~!
