Need help: Misfiring Cylinder.
Posted: May 11th, 2009, 1:03 pm
by tygr77
What has happened is that I've been putting of getting an oil change, and I didn't realize it, but I was driving with almost no oil. Yesterday I was driving in 3rd, and I hit 5000 RPM's and my engine just quit accelerating passed that. The next red light it stalled. I put oil in it, and got it running again, but at first there were really loud clanks (They stopped once the oil circulated). But now my piston is misfiring (It was before, but not as bad). When I start the engine, it takes along time to turn over, and after it finally does it will run with a clicking noise for about 30 seconds at average rev's, but then it will drop to 400-500 and shake violently. At this point, any thing other than flooring the gas pedal will cause it to stall out. I changed out the spark plugs already and I think it might be firing order, but I really have no idea whats going on. Does anyone know what it might be?
Re: Need help: Misfiring Cylinder.
Posted: May 11th, 2009, 8:53 pm
by Daveb
If your car stalled because it was out of oil, its a very, very, very... bad thing! Usually would mean finding a new motor.
If you think your motor is still viable, I would suggest starting with a compression test make sure the guts are working at least, and go from there.
Luckily 1.8 are reasonably priced, you should find a good one for $500 or less
Might as well get a KLZE
Posted: May 11th, 2009, 11:13 pm
by tygr77
I saw an add posted for a KFZE for $700, would that maybe be worth it?
Posted: May 12th, 2009, 4:53 pm
by SuperK
The firing order on the K8 is
<Passenger side Drivers side>
^Firewall
1.... 3.... 5
2.... 4.... 6
<>Radiator
I THINK! Someone confirm?
I would seriously check your firing order before digging in
Posted: May 12th, 2009, 9:57 pm
by tygr77
I already checked the order, thank you, I think I might need to time the distributor though, does anyone know how to do that?
Posted: May 13th, 2009, 9:54 am
by RX8SE3P
Lol puts off an oil change and drives with no oil whilst revving to 5000....
Just get a cheap DE. The K8 is probably half dead, it's not worth beating around the bush trying to fix it.
Posted: May 13th, 2009, 10:36 am
by SuperK
search young padawan. Search. there's a recent topic labeled "timing the distributor" if I remember correctly .
Posted: May 14th, 2009, 1:04 am
by tygr77
Ya but that just says the angle, I've never done it before and I was wondering if someone knew where I could find a step-by-step
