License plate light doesnt work.
I replaced the bulb but it still doesnt work. Is it a fuse or do you think its wire problems?
thanks for any advice
License plate light
License plate light
purple monster - 94 Mx3
Work in progress - 92 mx3
Re: License plate light
are both of them out or is it just one? they are wired into the parking lights fuse so if the rest of your marker lights work it must be something else... are you sure the wires to them are connected?
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
- Ryan
http://www.mx-3.com/manuals/photo.php?f ... download=1" onclick="window.open(this.href);return false;
wiring back up there is known to get corroded. Never gets washed. Gets all the oily crud from the road.
Sounds about right you got it lucky Istill have to drill new holes and make my plates lights custom it sucks!
so do you know if there is any way to fix this? could i just getm some new wires/ replace them. like splice them in or something. because i did check and the wiring is pretty bad back there. the previous owner didnt really keep good maintenance on this car,from what i can tell so far.
How do i install a new license plate light I wasnt thinking when i ordered the other parts from mazda. The bolt lens were so rusted i had to brake off the lens to try and see if the light would work. So i did but well i couldnt find the lens. So i bought a license plate light from canadian tire but there is no instructions. How would o mount this thing. It has no connectors just a one wire.
Need help thanks
Need help thanks
- Ryan
Whokid, I'm not sure what you bought, but its wrong.
You probably bought a trailer light. Those ground through chassis. You won't ground very well through a urethane bumper.
You need to either get new licence plate light housings, or go custom.
My solution was to drill out a hole in the back, insert a bulb socket from an old gauge cluster, solder new pigtails on it, and urethane the crap out of it. Works great so far.
I have a pic somewhere...
