how can i figure out exactly what engine i have
Posted: May 4th, 2009, 5:00 am
by asimpson719
i have a 92 mazda mx3 gs
it recently had a motor swap on it and im pretty sure it was just a newer stock motor that was installed if so then what motor do i have?
i know its a 1.8 v6 dohc
is it the k8? ive tried finding it on the block itself but cant.
help please!
Re: how can i figure out exactly what engine i have
Posted: May 4th, 2009, 5:52 am
by Redline322
The 1.8L v6 is the K8, if you look in by the injectors to the back head you should see a stamping K8 101, then that is a K8 for sure.
Posted: May 4th, 2009, 8:44 am
by Daninski
Search, KL Intakes or different intakes, something like that. There's pics of all the various intakes that will help identify what you have at a glance.
Posted: May 4th, 2009, 10:07 am
by Nd4SpdSe
You can use a K8 intake on a KL, so that may not be an accurate reflection on what motor he has.
Posted: May 5th, 2009, 5:23 am
by RX8SE3P
Look at the head codes. Takes approx 2 seconds.
I can post a pic if you can't find them.
