Valve stem seals ALL unseated?
SuperK
Post by SuperK »
I thought it might have been the head gasket... but I just got the valve stem seals replaced.
We took the head off and sent it to a shop to get new valve seals placed in...
However, it looks like they've ALL unseated
Look between the spring. See the shiny part between the middle of the spring? That's my valve stem seal. They're all like that.
Aren't they supposed to set IN the head, not ON the head, on the valve?
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
marcdh
Re: Valve stem seals ALL unseated?
Post by marcdh »
SuperK wrote:Aren't they supposed to set IN the head, not ON the head, on the valve?
Yep they should be locked in to the top of the valve stem sleeve section, they kind of audibly 'click' on with a decent amount of pressure.
Get your complaining hat on.
View Worklog
SuperK
Post by SuperK »
In the top left, you can see the valve stem seal between the spring.
Also noticable in the bottom right.
Are these seals too high? Or are they setting at the correct height?
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
marcdh
Post by marcdh »
I take you're getting lots of blue smoke then? I'm not familiar with that engine, I know on the KL heads they were seated very low. Are they all evenly high? I bet someone who's worked on the valvetrain will know right away. It's a pretty basic task, I'd be suprised if they didn't seat them right :?
View Worklog
SuperK
Post by SuperK »
I just don't understand what exactly could be wrong. The head was vacuum tested and wasn't leaking... new stem seals... new head gasket, but each cylinder is getting doused in oil whenever I run it, and smokes like the dickens
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
SuperK
Post by SuperK »
We pulled the head off again... Did a compression test, running 185-190psi in each cylinder...
But, with the valve cover off and the spark plugs removed, we turned the engine over (with the starter) and oil started puddling from the top of the piston and dripped lower....
However, there's no real tell-tale sign of valve stem seal leakage. There's a ton of oil, enough to leak out to the exhaust manifold.
Turn the engine a few turns and that's enough to make oil seep over the pistons.
The head gasket looked very well seated. No signs of leakage, no breaks.
Oil clean, antifreeze clean.
The cylinder walls look perfect. no scarring, no wear. The pistons look perfectly seated as well.
Is there a possibility that something is gummed up? It's ONLY oil that's coming in, I don't know exactly what else to be looking at.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
Mi|<E
Post by Mi|<E »
I'll take a picture of my stem seals on the B6 head I have and post here tomorrow
so you can compare and see if they are the problem.
(The head is on a bench so I can get to em easy)
SuperK
Post by SuperK »
That'd be great!
I've been told that the rings unseat when you remove the head. Any truth to this?
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
Ryan
Post by Ryan »
Sounds like BS to me. What on earth would cause the rings to move if you remove the head? Its not like the stress of the headbolts in the block deform the cylinder walls...
Post by wytbishop »
If the rings were not oriented properly when the engine was assembled I think you could see this. One time, before I knew what I was doing I assembled an engine with the wrong rings. 0.020" over pistons have 0.020" over rings to go with them as do the other oversizes. I put .020" over rings on .040" over pistons and they leaked like a bastard. Take the rings off one cylinder and check end gap. I'd bet $100 it's the rings one way or another.
fieromx3
Post by fieromx3 »
Ryan wrote:Sounds like BS to me. What on earth would cause the rings to move if you remove the head? Its not like the stress of the headbolts in the block deform the cylinder walls...
actually it does... headbolts torqued down will distort the cylinder walls a little bit... ever heard of torque plates? they bolt it to the block to simulate the head being bolted on when they hone the cylinders so the cylinders will be straight and true when the actual head is bolted on
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
fieromx3
Post by fieromx3 »
SuperK wrote:That'd be great!
and that is bs the rings do not unseat when u take the head off... its pretty dam hard for the rings to turn inside the cylinder.
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
Ryan
Post by Ryan »
Exactly what I was getting at. Of course the stress of several TONNES of tension in each bolt will distort it somewhat, but no chance it would be enough to harmfully affect tolerances, or move rings around. Mazda isn't that stupid, and if they were, they'd be much more "Zoom Zoom Boom" and way less 300+k
Post by wytbishop »
I saw a renowned professional engine builder on a very expensive 440 six pack install the rear main oil seal backwards AND install the cam shaft 20º advanced.
Mistakes happen.
Mi|<E
Post by Mi|<E »
It looks like they are on when the top is parallel to the 2nd coil with space
in between it if that makes sense..
if not:
