car dragging?
CrimsonReign1
car dragging?
Post by CrimsonReign1 »
my car started dragging (more in 1st and 2nd then any other gear) but it sounds like there are 2 engines running at the same time then it syncs and the car starts running normal again (if that makes sense). I found out my oil supply was bone dry so i filled it all up again, let it idle with the oil for a while then took it for another drive but its still running the same. it usually runs normal after around 4000 rms but its a bit differant everytime.
sorry if this has been posted before but i looked through the last couple pages and found nothing.
93 SE, black
Daveb
Re: car dragging?
Post by Daveb »
Ouch, running out of oil is very VERY bad. Is your check engine light on ? Check the accordian hose from intake to Air filter box (check box too) to start, duct tape tempory fix if anything leaking/Cracked.
If everything looks OK there, I d guess distributor, I ve got 2 burnt ones in my garage.
Checking your spark plugs, wires, cap & rotor good plan too.
good luck
CrimsonReign1
Re: car dragging?
thanks for the info, turns out it was the hose that goes from the intake box to the engine, major crack.
93 SE, black
Daveb
Re: car dragging?
Post by Daveb »
hah, i luv being right.
