RPM'S
- Daveb
Re: RPM'S
Mines in the paint shop so I cant do an exact check for you. Off hand i d say it sounds about right. Tire size will affect the accuracy of your speedo & therefore your RPMS.
Are you running the recomended 205 55 15 tires ? If not, you should check at your local tire shop to see if your tires are the correct height.![Smile :)](./images/smilies/icon_smile.gif)
Re: RPM'S
Yes it's very normal
viewtopic.php?f=15&t=69413" onclick="window.open(this.href);return false;
viewtopic.php?f=15&t=64863&hilit=highway+rpm" onclick="window.open(this.href);return false;
viewtopic.php?f=15&t=63607&hilit=highway+rpm" onclick="window.open(this.href);return false;
viewtopic.php?f=30&t=66187&hilit=highway+rpm" onclick="window.open(this.href);return false;
- stereoking15
Re: RPM'S
sorry pops this is a true sport compact, sorry if its not a gas guzzling v8 or diesel chugging around at 1.5k on the freeway, this is a high revving motor, anything below that for this motor is un-natural
