ok so im in the middle of getting everything for my swap and figure everything out so i have seachered but there still a couple things i need.
1) with the a/c mine needs to be recharged any chance i can disconect the lines and us the oneon my ze?
2) how much power does a/c take away from the car?
3)whats a good brand clutch that is affordable that will still grab hard?
4)with the cruse do i only hace to relocate the one line? and were to?
ok these next to i knoww are in the wrong form but its not for me ?
1) whats a good clutch for a bpt ?
2) do i use the harness it comes with?
klze swap questions
klze swap questions
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: klze swap questions
ok and what about thw awr mounts i have red up on them and hear good thigs but were is the best place to order the from and its only two mounts right that it comes with
rr-racing have a clutch with a fly wheel, you can look into that.
mccabe wrote:ok so im in the middle of getting everything for my swap and figure everything out so i have seachered but there still a couple things i need.
I don't know for certain, but I don't see why you couldn't use the ZE compressor. But don't do it yourself. once you get the motor installed go to a shop and have them do it. Reclaiming refrigerant is not simple and the stuff is really not good for you.
A fair bit.
I bought the Exedy stock replacement because I'm told by those I trust that it will hold as long as you're not thrashing it. There's a lot of clutch options.
You should be able to tee into any available vacuum source.
any one on the a/c
