How to install OEM spoiler?
Posted: March 23rd, 2009, 12:11 am
by drekati
I got an unpainted oem spoiler from ebay. How do i go about installing it? Cant find any info online. I assume it starts with taking the plastic off inside near 3rd brake light?
I am also about to get a paint job, just wondering if i should leave it off to get painted and install myself or see if the paint shop can do it. Any suggestions?
Re: How to install OEM spoiler?
Posted: March 25th, 2009, 12:42 am
by Dark_Rider2k3
it's been a while but you have to get inside that part. I remember I took the upper trim off, and then the plastic around that brake light. And there are like... 4 bolts i think? those come off, the black garnish piece comes off, and then the spoiler goes on (and bolts up in the same spots)
Posted: March 25th, 2009, 8:03 am
by Mad Cow
I think it's more like 6 screws but yea. Also, be careful when you're taking it off because you could break some mounting tabs even if it's all unbolted.
Posted: March 25th, 2009, 11:19 am
by 69shelby
remove the cover on the brake light, take the 3 plugs off the rear plastic trim, remove the 2 front side plastic trim pieces, remove the 3rd brake light, remove the 6 nuts holding the cover on the outside, reverse to install.
Posted: March 25th, 2009, 7:24 pm
by mitmaks
If you were closer I could shoot if for you. If you have local auto paint store have them load you a spray can and you can do it yourself and then clear coat it.
