Need help on drainning and filling my tranny
Blue Demon
Post by Blue Demon »
I have searched on how to change the fluid on a 1994 MX-3 RS Tranny (Original Tranny). I managed to drain the tranny from the Back Up Switch. Now I am having a problem on where to fill it up. Does anyone know where to fill it up from???
taylor_matt
Re: Need help on drainning and filling my tranny
Post by taylor_matt »
I have a 95 RS and i had to remove the speedometer sensor. It should be located on the backside of the tranny just above the intermediate shaft. Remove the bolt and pry it up, it will probably be stuck in there pretty good.
Thats the only way i know of to add fluid. Good luck
Blue Demon
taylor_matt wrote:I have a 95 RS and i had to remove the speedometer sensor. It should be located on the backside of the tranny just above the intermediate shaft. Remove the bolt and pry it up, it will probably be stuck in there pretty good.
OK I found it and I filled the tranny with the fluid. However, now my tranny wont shift into reverse? Did yours do this?
taylor_matt
hmmm that is weird. Never happened to me. Actually i'm just finishing up putting my bp in, I removed the speed sensor to add fluid in it as well. So i will check and see if i can shift it into reverse once i connect my shifter.
let me know if you figure anything out in the mean time.
Ryan
Post by Ryan »
Did you plug the switch back in? Did you try double clutching it a bit? 94's may or may not be synchronized for reverse. Try coersion.
Blue Demon
Ryan wrote:Did you plug the switch back in? Did you try double clutching it a bit? 94's may or may not be synchronized for reverse. Try coersion.
Ok I will try first thing in the morning. I will let you guys know what happen. Thx
ooELMOoo
Post by ooELMOoo »
what happened?????
| CUSTOM X3|
Return to “Transmissions”
