I Think some of the member here already saw this trouble on other Mx3 ! I Have a 1993 Mx3 GS with the K8 and the problem is the car will run normaly and stall suddently warm or cold, even if it's Cold, Hot or Raining outside ! It won't restart t'ill getting some sign of life, need to pump it when it does to get something of it, i've already reach to restart it and ran badly to good and after stalled again ! So I Checked the Fuel Pump Connection they are Good, Pump is working,i've checked there's Fire but now the car Won't start and ran the last 2 day without stalling !
Like describe on the net by other owner of the car they were talking about the ICM located in the distributor ( Ignition Control Module ) Mine is a little bit loose and moving ! So I Checked the Distributor, Primary Coil : 0,99 ohm ( SPEC : 0.43-0.79 ohm ) I Don't know if it's wrong if I have more than the Spec, I know that less than 0.43 Need to replace the Distributor !
Seconday Coil : I Need to recheck it so I'll give you my result soon ! ( SPEC : 20-31 Kohm )
Anybody as an Idea ?
![Question :?:](./images/smilies/icon_question.gif)
