some questions
Posted: March 1st, 2009, 1:46 pm
by mccabe
ok so i wont to redo my suspension because its gone so i have been searching around and found that the zx2 struts seems to be a popular choice with the suspension tec springs. what i wont to know is,
were the best place to buy the springs (i live in calgary)
i wont to buy new mount because my have cracks in them or atleast the front ones but what ones do i buy (were my strut bar sits)
I am also ording ZX2 Front Upper Strut Bearing,ZX2 front/rear dust boots,and MX-3 Camber bolts
anything im missing???
Re: some questions
Posted: March 3rd, 2009, 12:43 pm
by 96mx-3
im using the same set up... i just bought the springs from part source dont know if they have it there... the struts i bought from ford..but i have seen links on here for much cheaper then what i payed..and the mounts i would get from mazda or a junkyard..and dremel them out to the right size..
Re: some questions
Posted: March 3rd, 2009, 3:46 pm
by Evo_Spec
by mounts do you mean the rubber mounts? well actually, if there's any parts you need stop by the calgary pink n pull there's a couple mx-3's there
Re: some questions
Posted: March 3rd, 2009, 6:01 pm
by mccabe
yea i wont to buy new rubber mount but wont the zx2 work or not just it would make it easyer they looked close but i have inly seen pics
Re: some questions
Posted: March 3rd, 2009, 6:42 pm
by RS_OBD'oh_2
I picked up my HP's (for the mx-3) and eibach's at contemporary motorsports (was in the same building as tnt honda).. I think they moved, but worth while to give them a call. The upper strut mounts I got from mazda as well as the dust boots and bump stops. IIRC the hole in the upper strut mount needs to be drilled/bored out to fit the zx2 struts.. I could be wrong.
This will be the best upgrade most people will ever do. Enjoy it!
Re: some questions
Posted: March 6th, 2009, 4:39 pm
by mccabe
OK i know that you can use the mx3 ones what im asking is WILL THE ZX2 WORK IF I ORDER THEM FROM FORD I HEARD THEY WORKED?
Re: some questions
Posted: March 6th, 2009, 4:59 pm
by wytbishop
The MX-3 and Escort ZX2 upper strut mounts are the same. Exactly. Front and rear. If yo ucan find a low miles 95 - 00' Escort at pick n' pull...you're golden.
Re: some questions
Posted: March 12th, 2009, 9:32 am
by SuperK
Define: wont:
# One’s habitual way of doing things; To make (someone) used to; to accustom; To be accustomed; Accustomed
Define: want:
# desire: feel or have a desire for; want strongly; "I want to go home now"; "I want my own room"
# have need of; "This piano wants the attention of a competent tuner"
# privation: a state of extreme poverty
# hunt or look for; want for a particular reason; "Your former neighbor is wanted by the FBI"; "Uncle Sam wants you"
# lack: the state of needing something that is absent or unavailable; "there is a serious lack of insight into the problem"; "water is the critical deficiency in desert regions"; "for want of a nail the shoe was lost"
# wish or demand the presence of; "I want you here at noon!"
# need: anything that is necessary but lacking; "he had sufficient means to meet his simple needs"; "I tried to supply his wants"
# be without, lack; be deficient in; "want courtesy"; "want the strength to go on living"; "flood victims wanting food and shelter"
# wish: a specific feeling of desire; "he got his wish"; "he was above all wishing and desire"
Sorry, just a little grammatical OCD moment.
Re: some questions
Posted: March 12th, 2009, 10:41 am
by wytbishop
I am also wont to correct those who make simple mistakes...
That for instance, was a correction of his diction, not his grammar.
Re: some questions
Posted: March 12th, 2009, 11:08 am
by SuperK
wytbishop wrote:I am also wont to correct those who make simple mistakes...
I... I uh... I... damnit.
