I'm looking for a 1.6 SOHC intake vacuum nozzle/nipple...??
manowar821
Post by manowar821 »
I've taken off my old black intake tube, and I'm replacing it with a polished metal intake tube, for a short-ram intake setup. My problem is the place machined a metal nozzle for the oil-breather connection, but not the vacuum connection. The tube has a smaller metal nozzle, and then just a slightly larger hole further down the tube. I assume I'm supposed to get it professionally installed, but I know what I'm doing, and I've done things like this before. All I need is the nozzle/nipple to turn this hole into a connection for the vacuum hose. Arguably more important that the stupid oil-breather hose, am I right? :P
I don't have any idea where to find something like that, so I'm just going to bounce around the hardware stores and auto-shops for some kind of vacuum hose adapter... In the meantime, though, it'd be awesome if somebody here knew better than me. Hehe
Thanks again, MX-3 forum, you guys kick a--, proper.
