ok heres the deal...i swapped in a klze over the summer and have been doing little work now that its pretty much snowing every week here...but heres the problem...since i started driving it the car has been running really rich(little smoke and stinks)...the check engine lights still on (even though i had the ecu chipped which ive heard mixed reviews about what that does to the CEL, anyways...) it loses power on top end like crazy...after about 4 rpm in every gear the power just starts to even out...it needs a little starter fluid to start =/ it backfires when i turn it off...CHUGS gas...lots of problems....im thinking all running too rich related...so how do i get my baby up to snuff? what should i do/check? im thinking timing has a lot to do with it...i havent done a lot of reading about that yet but im definitely gonna...just wanted some insight first...and about the CEL? any suggestions would be helpful...thanks guys
PS if anyone wants to give any insight on timing that would be helpful too thanks
What should I check? lots of PROBLEMS
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
Re: What should I check? lots of PROBLEMS
Use common sense and check the codes, and it would be helpful to tell us about your setup (chip, vaf, ecu, etc.)
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
Running rich can also be indicitive of a vac leak. This may not fix the problem but I'm a strong believer in new O2 sensors. Who did you buy the chip from and if it was Ryan (probinator) was it the proper chip for your car (curved neck intake etc.)?
I always thought vac leaks make it run lean. If there's extra air coming in and the ECU doesn't compensate...Daninski wrote:Running rich can also be indicitive of a vac leak. This may not fix the problem but I'm a strong believer in new O2 sensors. Who did you buy the chip from and if it was Ryan (probinator) was it the proper chip for your car (curved neck intake etc.)?
I'd say the same, lean.Mad Cow wrote:I always thought vac leaks make it run lean. If there's extra air coming in and the ECU doesn't compensate...Daninski wrote:Running rich can also be indicitive of a vac leak. This may not fix the problem but I'm a strong believer in new O2 sensors. Who did you buy the chip from and if it was Ryan (probinator) was it the proper chip for your car (curved neck intake etc.)?
