Page 1 of 2
I NEED HELP!!!!
Posted: January 27th, 2009, 1:44 pm
by klmx08
i have a 92 gs with a 95 probe gt motor i want to turbo charge it this spring im not looking for crazy boost i just want about 5,6 pound can anyone give me a complete parts list to do this it would be much appreciated
Re: I NEED HELP!!!!
Posted: January 29th, 2009, 11:23 am
by mx3boyze
No, If you dont know what you need then you shouldnt be Turboing your car.
Re: I NEED HELP!!!!
Posted: January 30th, 2009, 4:25 pm
by klmx08
the only real question i have is do u have to use stand alone engine management (megasquirt) that is the only part i am not sure of if i can use millenia s injectors and a fmu that would be fine i dont want to mess with my computer but i would think that at idle it would run way to rich thats all
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 3:47 pm
by mx3boyze
Yes you can run an fmu with Millenia S injectors on the Stock ECU, But from experience I would say just get Megasquirt and dont be cheap if you really want to be serious about boosting your car.
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 7:04 pm
by hgallegos915
you can drive dirty like some of us at first for a bit.
Se7en wasnt even running with a wastegate LOL
Get to us if you need help
or add me on messenger
hgallegos915@msn.com" onclick="window.open(this.href);return false;
Im currently at 5 psi with stock injectors, 12:1 fmu and cosmo afpr.
YOU NEED A BACK UP CAR, unless you do everything right ... even still make sure this is not your primary method of transportation.
and and gas mileage... you can get better mileage in a suburvan by the way.
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 7:50 pm
by klmx08
its not that i want to be cheap but stand alone seems like a little over kill for 5 lbs of boost. is the gas milage really that bad im getting about 30 mpg now and i love it just how bad is it? if it is like 20 i think i could sacrifice!
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 7:52 pm
by Daninski
Don't listen to hgallegos915, he just has a lot of bad luck.
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 8:02 pm
by hgallegos915
lol I do have bad luck tho... LOL
for 5 psi u dont need msns
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 8:50 pm
by klmx08
i have heard that the stock kl injectors max out at 4 psi how did you get 5 psi on them?
Re: I NEED HELP!!!!
Posted: January 31st, 2009, 11:52 pm
by nos92mx3
psi is a relative term, its a hell of a lot different from a vj 14 and a garrett gt40r33
Re: I NEED HELP!!!!
Posted: February 1st, 2009, 3:13 am
by hgallegos915
klmx08 wrote:i have heard that the stock kl injectors max out at 4 psi how did you get 5 psi on them?
Where did you hear this? lol I have a read good working aem wideband, and my afs are good.. with the fmu.
My injectors havent maxed out.
I think its k8 injectors that mess up?
If you heard it on probetalk, chances are its not true. Unless shadowme told you so then yeah
Re: I NEED HELP!!!!
Posted: February 1st, 2009, 11:56 am
by johnmx3ze
im running with a FMU right now and i regret it i wanna get MS but its so expensive lol... i have a 12:1 fmu and stock injectors...
Re: I NEED HELP!!!!
Posted: February 1st, 2009, 2:16 pm
by klmx08
maybe it was the k8 injectors i had looked into turboing my k8 before i swapped it. i think i will just try a fmu on stock injectors and see how it works my mazda is no the only car i have to drive. let me just make my self clear im not trying to cheap out i want it to run good and if you guys have done it and it has worked i will give it a try . thanks for everyones help i really apperciate it.
Re: I NEED HELP!!!!
Posted: February 2nd, 2009, 3:00 pm
by hgallegos915
Use klze / klde injectors tho.
get a WIDEBAND. Dont skip that.
And upgrade the fuel pump. I got a 255.
Re: I NEED HELP!!!!
Posted: February 2nd, 2009, 8:37 pm
by klmx08
yeah i realized after i wrote it that i missed the wideband and i didnt know about the fuel pump thanks for telling me just out of curiousity how much did you spend on our set up i got about 2500 right now do you think that is enough? also isnt it true that the size of the turbo has to do with your powerband bigger turbo top end smaller turbo bottom end i want more bottom end my car feels strong at the top weak at the bottom if supercharger systems werent so expensive i would do that? so for bottom end power would a t3 from a sabb get me that?
