oil burn restrictor
Posted: January 2nd, 2009, 11:21 am
by nolig2278
Does the stock BPT setup need an oil restrictor or is the metal feed line to the turbo already limiting the pressure?
I went from 10/30 mobil 1 extended performance oil to 20/50 and bought a new cheap pcv valve, then saw smoke. Especially after leaving my parking garage. (a little too much oil caused some backup while going down)
Now I am on 5/30 and initially some smoke but seems to be lessening.
Thoughts/suggestions
thanks
Re: oil burn restrictor
Posted: January 6th, 2009, 2:32 am
by hgallegos915
If this is an ebay turbo chances are you will need to restrict oil flow ALOT.
I even had to restrict it on a real garret turbo I had.
Posted: January 6th, 2009, 8:54 am
by johnmx3ze
nolig2278 wrote:Does the stock BPT setup need an oil restrictor or is the metal feed line to the turbo already limiting the pressure?
thanks
if ever you need to restrict it and you need an oil restrictor PM me i have a brand new one that i bought for my klze-turbo project and i havent used it ...its stillbrand new and sealed...
Posted: January 6th, 2009, 9:19 am
by nolig2278
I have the stock BPT IHI VJ20 Turbo
Posted: January 6th, 2009, 9:34 am
by tehbrookzorz
20w50 seems really thick to me...
