oil in spark plug hole
Ok, so my car hasnt started in a while and i thought it was the ditsy so i did the hei mod with no external coil because i just replaced the old one with a new one and it didnt work so i check the plugs to see if they needed to be relaped and to check the plugs, but i find that there is oil in 2 of the 6 holes the ones on the valve cover the left and right ones i took the spark plugs out and they were in tight and looked fine so how did the oil get in there is it a craked sleve theres to much oil to so see ill let it settle back into the engine then look is it hard or can i even change the sleve if i have too?
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: oil in spark plug hole
I think its just the valve cover gasket. I had that problem.
Dam.. what hasnt happened to me..![Sad :(](./images/smilies/icon_sad.gif)
-hec
but would that make my not start
Change you gaskets and it depends how much oil. Oil can be conductive.
def. a valve cover
