need ideas
need ideas
OK so my car hasnt started for severl days it crank and crank but no fire so im guessing its the ditsy what are my options to replace it id look but i have no idea what im looking for. O and my cars a 92 gs
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: need ideas
When mine wen't I just got an aftermarket one for $250 instead of doing the HEI mod that makes your engine bay look like crap, and serves no purpose other then cutting costs!
So I would go after market and there you go! And you usually get a warranty with it. OEM will cost you upwards of $550 from the dealer, atleast when I worked there!
- onlytrueromeo
Re: need ideas
I think the HEI mod can look quite nice and getting an external coil means that you will have more juice going to your plugs. HEI mod can be done for under $100...
http://img247.imageshack.us/img247/5069/dsc004178sg.jpg" onclick="window.open(this.href);return false;
- onlytrueromeo
Re: need ideas
You can get a ZE disty and then it looks stock...
Or you can get one of the modified ones from probetalk I think.
- fowljesse
Re: need ideas
Yeah. Search "HEI mod". It's cheaper, more effective, more reliable, and a better platform for performance than getting another stock disty. Your spark will be stronger, if you get an MSD coil, so your gas mileage could improve, as well as top end power.
Whether your engine bay is less pretty, will be your opinion. I'm obviously more into performance than looks, especially in the engine bay. If you were trying to impress anyone with underhood looks, you could easily hide all the wiring, and make it look stock.
- onlytrueromeo
Re: need ideas
I like making things look pretty and go fast. If you get a ZE distributor ($50-100) there is a 7th nipple on it that is basically meant for an external coil. Get a nice external coil (MSD6a isnt bad) and mount it somewhere. The only thing you need to do is hide the HEI module, which like colins said, does not look good. You can put all the wires in a loom very easily and things WILL look stock.
The stock distributor is faulty which is why we don't recommend it. If you can get another one for about the same price that you can do the HEI mod for - than go for it! If it fails again, you might want to consider the HEI mod. Put up a [WTB] Working distributor thread.
