head swaps frankenstein
nlsolja123
Post by nlsolja123 »
i am kinda interested if a K8 head would fit on a klde?
I know the intake and exhaust would suffer but would the heads bolt up and any idea what the compression ratio would be if they do?
mazdags94
Re: head swaps frankenstein
Post by mazdags94 »
Just to guage your intentions as well as my curiosity, why would you want to do such a thing?
I think the heads shoud fit but the engine may not run efficiently. Also, i think the DE is a long block whereas the K8 is a short block. Not sure if this is 100% but if so, I'm also not quite sure how that would affect the setup.
marcdh
Post by marcdh »
Do the the water jackets and oil returns match at all with the bore being different? :?
This post sounds familiar, so familiar that as I wrote that I did a search:
viewtopic.php?f=15&t=65227&hilit=1+8+head+block
Not very conclusive, but some valid points. I'd sooner try having ZE heads on a 1.8 block, then turbo, and have awesome flow but on a lower drag/tax class. Infact I'll just stick to ZE :)
View Worklog
onlytrueromeo
Post by onlytrueromeo »
Please don't do this.
The ONLY Frankenstein you want is ZE heads on a DE block (or vice versa if you want stronger retainers but are too lazy to swap them). ZE heads are the best flowing heads. k8 heads are too small.
Just say no!
se7en
Post by se7en »
mazdags94 wrote:Just to guage your intentions as well as my curiosity, why would you want to do such a thing?
LOL, this is not the first time that I have heard this statement.
Long block refers to the complete engine, heads and all...and the short block refers to just the bottom end(no heads, etc)
the reason there is this confusion I think is because chevy had low deck and tall deck blocks(as well as ford, and others)the tall decks were used sometimes for industrial, and big truck stuff where the piston had three compression rings instead of 2.
oh, and ya, just say no to k8 heads on a DE.
Post by wytbishop »
having heads with smaller diameter combustion chamber thant the cylinder on which they sit will make for a really, really bad burn.
onlytrueromeo
You can compensate for the smaller head by increasing the length of the shaft, you know.
Post by wytbishop »
This is what I mean...
Those corners will obstruct flame propagation and create an excellent spot for the collection of carbon deposits.
Its just a bad idea.
Ya, I'm still wondering what would be the purpose of that...
mazdags94
Post by mazdags94 »
LOL.... learned something today :lol: . Good thing I followed my statement with "i'm not 100% on it."
nlsolja123
the reason im asking is the honda people put 1.5/1.6 blocks and heads together, as well as the b series 1.6/1.7/1.8/2.0 block and head combos, it give advantages in tq while keeping hp close to the same. also would it be possible to put kl heads on a k8?
Post by wytbishop »
KLDE and KLZE heads are effectively interchangeable.
If the difference in displacement was small (meaning that the difference in bore size was small) the problem would not be so noticeable. You would still have a serious carbon collection point though where the smaller combustion chamber overhangs the cylinder wall.
SuperK
Post by SuperK »
onlytrueromeo wrote:You can compensate for the smaller head by increasing the length of the shaft, you know.
This is somewhat true, however, if you have a small head, then there's less to "catch" during your "revolutions" thus rendering a less than optimal experience.
It needs to be a balance between head and shaft size. One exaggerated size compared to the other isn't optimal.
... Or so the girlfriend says.
Wait, what are we talking about again?
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
onlytrueromeo
Enough with the innuendo.
Inyourendo.
RX8SE3P
Post by RX8SE3P »
SuperK wrote:This is somewhat true, however, if you have a small head, then there's less to "catch" during your "revolutions" thus rendering a less than optimal experience.
:lol:
1995 Eunos 30x KLZE
