exhaust size???
- johnmx3ze
exhaust size???
hi people, i wanna get a new exhaust systeme but i dont know witch size would be good for me? klze turbo...because right now i still have the stock exhaust and i want one in stainless... so how big should i go? 2.5"? or bigger?
![Image](http://i470.photobucket.com/albums/rr69/johnmx3ze/JonNEWsignatureVredSMALL.jpg)
- Ryan
Re: exhaust size???
turbo, I vote 3". There is a lot of talk of that on here.
b6 don't go past 2, v6 N/A was 2.5, and any turbo application was at 3".
At least I think that was a general consensus.
- mazda915
Re: exhaust size???
I say 2.5 with a 4 inch tip not to big or small . Well good luck bro on ur decision .
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
- solo_ryder
Re: exhaust size???
2.5" on a low boost KLZE
- hotsiit
Re: exhaust size???
3 inch downpipe out the side of the front bumper ![Wink :wink:](./images/smilies/icon_wink.gif)
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
![Image](http://i603.photobucket.com/albums/tt118/hotsiit/mx3-into-1-1.jpg?t=1242927937)
1983 Mazda RX-7 GSL
1987 Jeep Comanche
Re: exhaust size???
I agreesolo_ryder wrote:2.5" on a low boost KLZE
if you want reasons why, do a search it has been argued/debated many times!
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
Re: exhaust size???
Win!hotsiit wrote:3 inch downpipe out the side of the front bumper
I would just do a 3" .
though that also depends on what size exhaust side you run on the turbo and what turbo you use.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- johnmx3ze
Re: exhaust size???
my exhaust size on the turbo i think is 2.5 and im using a T3/T4
- onlytrueromeo
Re: exhaust size???
def. stick w/ a 2.5" exhaust and you'll be fine unless you plan on putting down 350ish hp (which is quite a bit if you're using it as a daily driver on a FWD car)
Side exhaust would be cool though
You should just go w/ no exhaust and have it end after the downpipes/turbo! It'd sound bada55!
Re: exhaust size???
What i meant by exhaust side of the turbo is the a/r of the exhaust side.johnmx3ze wrote:my exhaust size on the turbo i think is 2.5 and im using a T3/T4
As in if you were using a .48,.63,.82 etc etc..
say if you were using a .48 a 3 inch exhaust would leave little benefit for you, since your biggest restriction would be the exhaust housing itself.
vs the .63, .82 where i would almost say the 3" is required to make the most power.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
- johnmx3ze
Re: exhaust size???
i dont know thats my turbo...
http://www.cxracing.com/mm5/merchant.mv ... _Code=TOCH" onclick="window.open(this.href);return false;
Re: exhaust size???
3" is what you want.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
