WTB set of motor/transmission mounts for 94 MX-3 with AT
Posted: October 18th, 2008, 5:19 am
by GringoEJS
I would like to replace all 4 mounts on our 94 MX-3. They need to be from a 94+ 1.6L automatic. I mainly need the 3 mounts at the tranny (front, rear, and driver shock tower) but will buy a complete set as long as they are in good shape, I am interested. Can pay with PayPal and looking to buy immediately.
Thanks
Re: WTB set of motor/transmission mounts for 94 MX-3 with AT
Posted: October 19th, 2008, 1:49 am
by Daninski
You could buy Duratane 94, clean yours and fill them with this product. For $50 bucks it's the best but for the buck.
Posted: October 19th, 2008, 9:19 pm
by GringoEJS
Wow, I never even considered that. After not being able to find anything on Duratane on the internet, I did find this thread
http://importnut.net/motormount.htm" onclick="window.open(this.href);return false; and I will give that a try. Thanks for your suggestion, Daninski!
Posted: October 19th, 2008, 10:42 pm
by Daninski
OK any product that's a one part system requires air to dry. You can't put it on too thick or it won't cure properly. Layering is not the best way to go either. I strongly suggest you use a two part system. Your looking at a chemical cure and it's going to be a stonger better product. Here is a place to start.
http://www.plasticworld.ca/Devcon.htm" onclick="window.open(this.href);return false; A $10 buck product is not going to fix your problem. A product like Durathane 94 is meant for forming replacement rubber products.
