sensor?
sensor?
quick question: whats the sensor next to the green coolant temperature sensor? its pretty much the same thing...by the way the manufacturer of these engines wasnt really thinkin when they made the engine hoist spots on the engine cause thats where i lifted it from and thats what broke the sensor...
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
- tehbrookzorz
Re: sensor?
i thought the green one was the temp sensor...
- tehbrookzorz
Re: sensor?
Well, one's for the ecu and one's for the dash, I just don't remember which is which at the moment.
Cody
