blaster ss vs blaster 2
i searched on here for the blaster ss and there was only 8 results so i dont know whats goin on with these... im about to do the HEI Mod so i was hopin to get some info on which one you would suggest...thanks
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
- fowljesse
Re: blaster ss vs blaster 2
I have the 50,000v Blaster SS. The little squarish one. I haven't put it on yet, though.
- JWMX3
I found lots of positive feedback on the ss over at probetalk, thats why i bought one
- solo_ryder
I would go with the SS as you can mount that anywhere, the blaster 2 is oil filled and needs to be mounted a certain way and is ugly IMO.
I agree... on my next build I am using the SS.solo_ryder wrote:I would go with the SS as you can mount that anywhere, the blaster 2 is oil filled and needs to be mounted a certain way and is ugly IMO.
The Blaster is a good coil, but the SS is smaller, does not require an extra bracket, can be mounted in any position (you should mount the blaster vertically, noticed some pictures of them not mounted that way). I manage a speed shop. They both cost almost the same, so get the SS. When the Honder guys first started putting on external coils the SS was not out yet. I think the original blaster coil's continued popularity is based on Monkey see, Monkey do. I am building a 323 KLZE based on that Monkey theory so eek, eek throw some poop I guess.
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
- fowljesse
Monkeypoo.
I'm going to plug my coil tower directly into myZE disty cap, since there's the 7th nipple.
That way there's less resistance.
I know, I know, it won't make a real difference, but I like the butt dyno difference. I'm also going to make my plug wires out of a kit, and make them as short as possible. I cut down my GS wires, and save almost 6 feet. I like to believe that with 50,000v, an MSD 6A, and that much less resistance, it will make a difference with my setup. If not, no harm done
