Brake fluid
teach
Brake fluid
Post by teach »
I need to top up my brake fluid. I have some DOT 3 but it says for ABS. Can I use this to top up even if my brakes aren't ABS?
96 MX3 ATX 1.6L
Towona
Re: Brake fluid
Post by Towona »
I think that is "ABS safe" fluid more than "only for ABS". But, for a couple bucks, why not buy another bottle and have piece of mind?
teach
Re: Brake fluid
Post by teach »
Thanks, I think I'll do that.
96 MX3 ATX 1.6L
Dark_Rider2k3
Re: Brake fluid
Post by Dark_Rider2k3 »
If I'm correct, all dot-3 brake fluid says "ABS Safe." I am like.. 90% sure that you can use any DOT-3 brake fluid, as long as it is indeed DOT-3
4gotn
Re: Brake fluid
Post by 4gotn »
dot 3 is dot 3 and most of it is synthetic
it will enter change no matter the circumstances...but really..i think you should drain your system and put dot 5 in there
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
Dark_Rider2k3
Re: Brake fluid
4gotn wrote:dot 3 is dot 3 and most of it is synthetic
why dot-5?
4gotn
Re: Brake fluid
Post by 4gotn »
higher boiling point
doesn't absorb water so it doesn't crap out as easily
that and it doesn't harm paint for when you make an oops
but i mainly used it because when you mix that with steel braided lines you have virtually no play in the hydrolics
Dark_Rider2k3
Re: Brake fluid
4gotn wrote:higher boiling point
hmm that's interesting... i knew about the higher boiling point, but not about the other stuff.
is it easy to switch from dot-3 to dot-5? I am in process of getting a few things (mainly: exhaust, new fuel pump to be on the safe side, a few "goodies"), but my boss can get me a good deal on S.S lines, and if I do take him up on his offer, i'm just wondering if it would be a smart thing to switch over to dot-5.
4gotn
Re: Brake fluid
Post by 4gotn »
drain the old
insert the new
bleed the brakes till you see the new fluid color
Dark_Rider2k3
Re: Brake fluid
oh sweet that's easy as hell :lol: .
I think I found a project for me friday :o .
