Compression Test
Ashton Janzen
Compression Test
Post by Ashton Janzen »
Does anyone know the compressions for a Mx3 1993 GS
solo_ryder
Re: Compression Test
Post by solo_ryder »
Correct me if I am wrong, should be around 200psi
fowljesse
Post by fowljesse »
I believe it's 195 new. If it's not lower than 185, and there's not more than 30% deviation, it's fine.
ElectricEnergy
Post by ElectricEnergy »
As far as I know, for the US V6 its 180psi with less than 20% deviation across all cylinders. The KLZE is 200psi with less than 20% deviation. It should say in the shop manual somewhere.
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
