Hey guys forgive the n00bness of this post as i have not been able to locate a post that explains this..
is it possible to fit a KL motor into a vehicle that currently is running a BP?
thanks
marty
BP- KL swap.. possible?
Re: BP- KL swap.. possible?
Short answer yes, search is your friend.
It's the same as any 4cyl to V6 conersion. Lots of stuff to replace if you do that. With a BP, I'm surprised you don't just slap on a turbo, your 3/4 the way there anyway
It's doable, will need a few things from an MX3. Check ClubProtege for a few detailed threads (including mine where I went from a B6 to a KLZE in a 323).
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
hgallegos915
If you got a bp.. any chance u can sell it to me?
-hec
you should just turbo the bp it might save you a big headacheNd4SpdSe wrote:It's the same as any 4cyl to V6 conersion. Lots of stuff to replace if you do that. With a BP, I'm surprised you don't just slap on a turbo, your 3/4 the way there anyway
92 Blaze Red MAZDA Mx3 <GS> ZE, millenia manifold. gutted interior, filled mounts, fidanza fw, act 6puck.
Your a poet Dude thats for sure. lolhgallegos915 wrote:If you got a bp.. any chance u can sell it to me?
