Ground Wires
Posted: September 1st, 2008, 12:18 pm
by MazdaRider
what do u think do u think that this is a good ground wire DIY http://www.clubprotege.com/wil/howto/groundwire/" onclick="window.open(this.href);return false;
or am i just better off buying one
Re: Ground Wires
Posted: September 1st, 2008, 9:09 pm
by npspears
This way should be less expensive than actually buying ground wires from a company and it is the same or better quality.
Re: Ground Wires
Posted: September 1st, 2008, 10:53 pm
by RS_OBD'oh_2
It will be less quality (for some like apex, sun auto, hks, nrg) who use low/no oxygen exposure to their copper. But... this will work fine. Please use heat shrink and make sure that there is an FT rating for the insulation so it doesn't melt.
Re: Ground Wires
Posted: September 1st, 2008, 11:28 pm
by Ryan
I have some leftover wire from my amp kit... it looks to be a heavier guage than the wire that is currently on my neg battery terminal.... I think its only 8 guage.
Re: Ground Wires
Posted: September 2nd, 2008, 12:57 am
by MazdaRider
So it would be better just 2 buy a kit
than rather make it
Re: Ground Wires
Posted: September 2nd, 2008, 1:34 am
by RS_OBD'oh_2
That is pretty hard to say. If you can take your time and make sure that your lugs won't take on moisture then make your own. If you plan on rushing it and not using the correct tools, forget it. If you will only save 10-20 bucks, I wouldn't do it. Please keep in mind that the kits out there are designed to take the heat under the hood. Amp kits may not.
Re: Ground Wires
Posted: September 8th, 2008, 12:03 am
by MazdaRider
so over all its better 2 buy the kit then make it
Re: Ground Wires
Posted: September 12th, 2008, 12:02 pm
by MazdaRider
all right guys bought a hyper voltage stabilizer just installed today
waiting on my ground wires
the i bouoght the kit
how i have a question where do i connect the ground wires to i have a 94 b6 if it helps
Re: Ground Wires
Posted: September 13th, 2008, 12:07 am
by Ryan
I would assume you replace all the ones that are already there and then keep adding them to important parts untill you run out. Like your engine, your fuse box, starter.... I can't think of anything else really
Re: Ground Wires
Posted: September 13th, 2008, 3:20 pm
by MazdaRider
actually i never had any on just waited fro my kit 2 come in then went from their
Re: Ground Wires
Posted: September 13th, 2008, 3:23 pm
by RS_OBD'oh_2
You MUST replace the stock grounds. If you don't, you run the risk of having "potential difference" between your grounds and will burn up your old ones.
