Sway bar links (how much play?)
When I did my frt brakes I notice some play in the swaybar link, not sure how much play is normal, should it be tight or a little sloppy? Thanks.
Re: Sway bar links (how much play?)
all it is is another form of ball joint a lil play isnt too bad but if you can move it back and forth a 1/4 inch or so there gettin close so order u some new ones then be ready to cut your old ones off theyre a real
one thing or another itll strip
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
LIFE IS A SEXUALLY TRANSMITED, TERMINAL, DESIESE. AND WE ALL SUFFER FROM IT.
