Intake
Posted: July 25th, 2008, 11:53 pm
by Ashton Janzen
Ok I am installing an intake on my 1993 Mx3 GS. There are a few small black houses coming from the main big one. Are these inprotant or should i just tape them up. I counted like four which are the inportant ones.
Re: Intake
Posted: July 26th, 2008, 1:13 am
by Dragyn Vyrus
all of the hoses are important...
i don't know what ones your talking about in particular, but you shouldn't be taping any hoses up...
Re: Intake
Posted: July 26th, 2008, 4:03 pm
by TOOgreezy
Ashton Janzen wrote:Ok I am installing an intake on my 1993 Mx3 GS. There are a few small black houses coming from the main big one. Are these inprotant or should i just tape them up. I counted like four which are the inportant ones.
i installed an intake last week...
for sumreason after the 1st day it made my car run a little weird... it was taking long to start up.. felt like it was losing power.. idling realllly low.. which made the car kinda shake while @ a complete stop it was just weird so i took it off and put normal airfilter back.
heres a video of the day i installed it
it was jus the cone tho not the cold air
http://youtube.com/watch?v=vD4NtHOlz8I" onclick="window.open(this.href);return false;
that hissing noise u hear wasnt there before i installed it.. so maybe that had sumthin to do with it
Re: Intake
Posted: July 26th, 2008, 4:35 pm
by Daninski
Just plug all the hoses in where they were. If they were coming from the mani then install them there. One should be before the VAF one after the VAF. A hose for your FPR and so on and so on. Go look at another MX-3 if your unsure and copy it. Every hose is precious.
Re: Intake
Posted: July 26th, 2008, 8:07 pm
by tmac4t4
i scanned this for greezy but i might as well just post it here,,hope it helps you guys out.
![Image](http://i295.photobucket.com/albums/mm158/tmac4t4/IMG_0284.jpg)
Re: Intake
Posted: July 26th, 2008, 10:12 pm
by Daninski
Schematics are ok but I found looking at another MX-3 is pretty much a no brainer,,,good for me. Wheather it's the factory engine or a ZE it should look identical to whatever came out of your car when it goes back in or on as is your case. Go look at another MX-3 then make yours look the same and that's 90% of the game.
Re: Intake
Posted: July 28th, 2008, 2:00 pm
by hgallegos915
you can block the hose going to the stock box.
